GLITCH - V8 - Match Srf - this was hard to catch -
Switching Average Surface in MatchSrf change the control point style from DOT to SQUARE:
It’s the same in V9Beta.
@Gijs I may tag you?
This changes the weight of the control points, which is a highly unwanted behavior.
The weight of the control points must remain the same for surfaces that already have enough control point rows to fall under the target G1 or G2 continuity.
Changing of the CP weight is only needed when a surface with fewer control points and degree 1 or degree 2 is matched to a higher continuity (G2) that require extra rows of control points.
@Rhino_Bulgaria I think you’re mixing up the square dot with the diamond dot?
@skysurfer is this a display glitch? Does it change the control point style for every surface, and does it stay like that if you reselect?
Ah, yes. My bad.
But my statement stays true just in case that something wrong goes in Rhino 9 in this regard.
Changing control point weight is not needed for non-rational curves or surfaces when control points are added. If the shape is to be preserved then the locations of the control points after the control points are added will differ from the original locations, but that has nothing to do with weights for non-rational curves or surfaces. (See inserting knots and increasing degree.)
Depends on the situation and whether the user prefers keeping the control points as close as possible to their original position. Changing the CP weight is a known method to modify the shape of a surface while keeping the total number of control points the same or at minimum. You can effectively change the whole shape by altering the CP weight and still keep the location of the control points intact. It’s useful in certain cases.
However, this is also an easy way to introduce bugs and unwanted results depending on the adjacent surfaces and which other tools are used to build the model. Both, “Match surface” and “Blend surface” are prone to bugs when weighted control points are involved. Other tools such like “Loft” are not affecting as much.
It happens only during the matchstf command.
I didn’t try with multiple surfaces.
Did you get it too?
Hi skysurfer -
I’m not seeing that here.
Please post the output from SystemInfo, and if possible a 3dm file to make sure we’re looking at the same thing.
I was fascinated that I hadn’t noticed it before, so I tried it myself, but the shape of the point doesn’t change.
Sure!
SysInfo:
Rhino 8 SR33 2026-6-17 (Rhino 8, 8.33.26168.09001, Git hash:master @ 2ded7b8c3751efbca7caacdffcbe8f8c60fb77b8)
License type: Commercial, build 2026-06-17
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.19
Computer platform: LAPTOP - Plugged in [92% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 4-18-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 595.79
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Users\XXXX\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.33.26168.9001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
This is the file: Dropbox
Video:
I think this may be because you have a Point Style square in the display settings.
See: Options > View > Display Modes > Shaded > Objects > Points
If I change the Point Style there to “Square with white center”, I see the same : as soon as MatchSrf comes on, the CVs change from round to square. When Average is then activated, the other surface also changes its CVs from round to square.
