Hello, this is a structure column made of steel members with glass cladding on to the exterior of the column. the glass panels must be on offset 6 cm from the outer face of the steel which I have done.
my problem is that I can’t control the size of the glass panels that the edges meet each other, i want to be able to control the connection between panels. so later i would be able to have the accurate size of the panels for fabrication.
thank you for your time.
Mosque Column for fabrication analysis.3dm (5.5 MB)
Mosque Column for fabrication analysis.gh (18.3 KB)
