Glass panelization of hyperbolic surfaces
I would like to have the blue double curved surface of the roof made of glass. I made it from many surfaces with the “Surface from 2 edge curves” command. The 2 edges are straight lines, that do not lie in the same plane. I think this is called a hyperbolic surface. The surface in the middle is a hypar as well. What do you think would be the most efficient way to cover it with glass? Thank you!
Hi Elista - I guess the best place to start is with Paneling Tools - http://www.food4rhino.com/project/panelingtools?ufh
You might look into the Evolute Tools plug-In too.
Norbert Geelen
