If I assign the material “glass” to a window from VA via the layer, this will not be rendered. Even if I turn off the plane.
Any ideas where the problem lies?
Thanks and regards
EikeWindow_test.3dm (3.1 MB)
Thanks and regards
Hi ERahjes
V-Ray materials for custom render mesh objects (like VA’s objects) will be supported in the next update of V-Ray Next for Rhino.
Hey Nikolay,
I use Vray 3.6.
Assigning materials in VA has always worked.
working with v-ray next .
Inside room.
Outside
ok… the next weired thing…
i downgraded to 3.60.02 and now this is happening, the window is invisible - magic?
I think you need to check vray Render output settings then try to active safe frame.
