Ghtext as geometry : i.e. chance to use the generate text and transform it
unhandled
#1
HI
I am wondering if there is a way to keep using the text generateD by native GH text components such as text tag and text tag 3D .
let me explain , I am driven by need to keep tranforming the generated text ( scaling , rotating , moving ) but the native GH text components do not have an exit.
I solved the problem by using an external plugin called “Fabtools” supplyed by http://blickfeld7.com/ , this plugin works great and do have a 3D text tag that generated a trasformable text , the problem is the after switching to RH wip this 3D text tag component is not working , here is the error
any suggestion ? any way to use the generate test and transform it according to my need ?
thanks , cheers
Ivan
