Ghpythonlib.components throws error
Hi
I have an issue with calling gh components from python script.
The code below throws this error:
Am I doing this wrong or is this a bug?
Hi @Johan_Lund_Pedersen,
Can you provide the .py or .gh file - whatever we need to reproduce?
ā€“ Dale
I can replicate this and files a ticket to get it fixed:
RH-81296 ghpythonlib CullDuplicates can not convert python 3 inputs
#! python3
import Rhino.Geometry as RG
from ghpythonlib.components import CullDuplicates
points = []
points.append(RG.Point3d.Origin)
a = CullDuplicates(points, 100)
print(a)
@Johan_Lund_Pedersen Which Rhino version are you using?
Hi @eirannejad
Thank you.
Rhino 8 - 8.5.24072.13002, 2024-03-12
Hi!
I also have a similar issue. I am using, Version 8 SR6 (8.6.24101.5001, 2024-04-10).
what is the solution for using ghcomponents in Rhino8? Or am I doing anything wrong here?
Thanks!
8.6 is a bit earlier then ehsan fix. Please give 8.7 a try. Under check for updates Iā€™m the help menu set the build to release candidate and a newer build will be available.
