I am currently writing a python component that extend both sides of a list of curves onto the boundary if both endpoints falls within the boundary.
The list of curves called partitions are input into x and I set it as List Access Curve Type
The boundary I set as Item Access Curve Type
The error shows is Iteration over non-sequence use of polyline curves
Any help will be much appreciated. Thanks.
extendCurve trial.gh (5.8 KB)
extendCurve trial.3dm (23.4 KB)
Hope this help:
import Rhino.Geometry as rg
if boundry.Contains(line.To) == rg.PointContainment.Inside and boundry.Contains(line.From) == rg.PointContainment.Inside:
curve = line.ToNurbsCurve()
a = curve.Extend(rg.CurveEnd.Both, rg.CurveExtensionStyle.Line, [boundry]);
ExtendCurve.gh (2.9 KB)
I tried and it works. Great thanks.
Hi Mahiyar,
I tried your few lines of code and it works perfectly for curves. However if any item in the list to be extended to the boundary is a polyline, the script gives an error when I try also to extend both ends to the boundary.
It says polyline doesn’t have the attribue ‘To’ and in the polyline class of the rhino library, I couldn’t find a way to extract it’s endpoints.
Another way I tried is to explode the all lines, if the length of the list is greater than one, meaning its a polyline, then get the first index and the last index of the exploded list of lines. However, an error msg shows ‘Guid’ object has no attribute ‘ToNurbCurves’.
Do you know anyway I can extend the two ends of the polyline to a boundary that contain it?
Thanks.
extendCurve trial.3dm (22.7 KB) extendCurve trial.gh (11.7 KB)
if boundry.Contains(curve.PointAtStart) == rg.PointContainment.Inside and boundry.Contains(curve.PointAtEnd) == rg.PointContainment.Inside:
ExtendCurve.gh (3.3 KB)
