Hey, Im trying to make my CustomDisplays work out with preview toggling of the ghPython-component on the canvas. My approach is to intercept the ghenv.Component.ObjectChanged
event and then do ghenv.Component.ExpireSolution(True)
. I have two issues however.
- My event handler class cant seem to run the assigned functions on fired events, should i use func(sender, e)-pattern for Grasshopper events or how can I deal with them in th ghPython node? The code below makes the node update on fired events if i change
event_handler.subscribe(ghenv.Component.ObjectChanged,event_handler.test,'obj_changed')
toevent_handler.subscribe(ghenv.Component.ObjectChanged,ghenv.Component.ExpireSolution(True),'obj_changed')
. Why is this? (sry about the broken formatting, I don’t get why it happend)
class event_handler():
def init(self):
if ‘events’ not in sc.sticky:
sc.sticky[‘events’] = {}
event_handler.subscribe(ghenv.Component.ObjectChanged,event_handler.test,‘obj_changed’)
@staticmethod
def test(sender, e):
print sender, e
@staticmethod
def subscribe(event, func, key):
if key not in sc.sticky['events']:
sc.sticky['events'][key] = event
if key not in sc.sticky:
sc.sticky[key] = func
event += sc.sticky[key]
@staticmethod
def unsubscribe_all():
for key in sc.sticky['events']:
if key in sc.sticky:
sc.sticky['events'][key] -= sc.sticky[key]
sc.sticky.Remove(key)
sc.sticky['events'] = {}
my second issue is to limit the event only to Hidden toggle, and not zoom, pan etc. But I guess I can just typecheck or something?
Many thanks
Jakob
