Ghosting Left Behind (Bug)
Haven’t had this problem till today. Seem like other people have run into it to.
It only happens when I use both gh and player. As you can see in the video the ghosting did not show up till I opened gh.
So, in essence, it leaves behind all the gh things that happen.
Not only that but when I close the gh tab the previewed geometry from that tab is still left behind.
Untitled design
System Info.txt (2.6 KB)
Is there anyone that can help on this? This bug is getting really aggravating.
If you’re in Rhino 8, there is a toggle that you can uncheck to close the file after the GH Player command is run. See this thread (Loops while in compiled GH or Grasshopper Player - #3 by AndyPayne). Also, if you have the remote control panel open, you might try closing that.
Thanks @AndyPayne
I am in Rhino 7.
I will check the RCP panel and see if that fixes it.
Maybe you can adapt your script to work with this: Loading a gh file, executing it and harvesting its data - Grasshopper Developer - McNeel Forum
