How do you set your model to ghosted in I rhino 3D?
It is only possible to display things in the Rendered view. If you look at the example files and find the drill, you can see the closest possible option. Just use some color, a little bit of transparency, and some glossiness as a simple shader. That will created a sort of ghosted view.
