I’m excited to announce GhJSON, a new JSON-based standard for representing Grasshopper definitions. What started as an internal need for SmartHopper has evolved into a reusable, open-source library that hopefully will benefit others in the Grasshopper ecosystem.
The Problem
Working with LLMs and AI tools requires translating designs into text. Binary .gh files aren’t directly processable by language models, and .ghx files contain too much metadata for efficient AI understanding. I needed a format that captures the essential structure and logic of Grasshopper definitions while remaining lightweight, human-readable, and AI-friendly.
The Solution
GhJSON is a standardized JSON format for Grasshopper definitions, inspired by existing community efforts like GHPT and WolfParametric’s wolf-community-scripts. I have documented the specification, made some tweaks, optimized it for AI processing, and built comprehensive tooling around it.
What You Can Do With GhJSON
- Serialize Grasshopper definitions to JSON for AI analysis, version control, and sharing
- Deserialize JSON back to the canvas with full fidelity (not all components are compatible yet)
- Validate definitions against the schema
- Merge multiple definitions programmatically
- Extend with custom handlers and serializers
Getting Started
GhJSON.NET is available as two NuGet packages:
- GhJSON.Core: Platform-independent document model and operations (read, write, validate, fix, merge)
- GhJSON.Grasshopper: Grasshopper integration (serialize from canvas, place on canvas, data type serializers)
Explore the full specification and documentation at:
- GhJSON Specification: Complete format reference
- GhJSON.NET Repository: Source code, examples, and contribution guidelines
Why This Matters
GhJSON is designed to be:
- Human-readable code: While it is code, it is not (so) cryptic.
- AI-friendly: Optimized for language model processing and understanding.
- Extensible: Easy to add support for custom components and data types.
- Reusable: A standalone library that any .NET project can leverage.
- Community-driven: Open source and welcoming contributions.
Started in SmartHopper
GhJSON emerged as a natural evolution while building SmartHopper, the first open-source AI-powered Grasshopper plugin. Rather than enclosing this functionality within complex logic with mixed concerns, I separated it into a standalone library so that the entire community could benefit. SmartHopper now uses GhJSON as a core library, and it would be great to see that other plugins can benefit from it.
Building synergy begins with an open standard.
Happy designing! ![]()
