Gh1 in WiP not passing the linetype properties
Yellow circle is a Rhino object with Hidden linetype assigned.
Green lines are Gh objects that displays as continuous regardless the hidden linetype properties assigned. I have tries several ways, no change.
Hi Piotr -
This seems to work:
2025-09-11 Grasshopper Linetype
This also works but the panel cannot go directly into the preview component.
Ah, this way.. thanks for explanation. I was looking for solution under Objects tab….
