GH Style objects - Pick Object?
Hi there.
I wanted to ask if there was a way already, or if it would be possible to implement a pick object option within grasshopper styles? It would open up a bunch of abilities. I created a really fast example of this:
The Change happens after I run VaUpdate
Create Cabinet.gh (10.8 KB)
But there’s a bunch of possibilities with having an ability to reference geometry within VisualARQ components.
Hi @rheinason,
That’s already possible. You can use a Curve Param or Brep Param input components, and VisualARQ will allow you pick a curve or a brep from the properties panel:
Here is an small definition for a custom GH Element that creates a pipe object. Just create a new Element Style from a GH definition, and set “Curve” and “Radius” parameters to be defined by Object.
pipe.gh (4.3 KB)
Let me know if that is what you were asking for.
Regards,
Enric
