Hello, i have a problem, Gh scripteditor won’t open, i tried right clicking open script editor but nothing happened, this problem shows in all 3 scripting languages (C#, Ironpython2, Python3), Rhino Script Editor works just fine, thanks.
Hi William -
Please run the Rhino SystemInfo command and copy-paste the output here.
Hi Wim, i run the command ScriptEditor in Rhino and it didn’t opened, here is the error when I run Rhinocodelogs command:
info 08-10-2024 6:40:43 [RhinoCode] Language Registered: Grasshopper 1.0 (mcneel.gh1.grasshopper)
Info 08-10-2024 6:40:43 [RhinoCode] Language Registered: Markdown 0.30.4 (mcneel.markdig.markdown)
Info 08-10-2024 6:40:43 [RhinoCode] Parsing configs schema “https://files.mcneel.com/schemas/rhinocode/editor.schema.v1.json” in C:\Users\willi.rhinocode\editor.json
Error 08-10-2024 6:40:44 [RhinoCode] Error opening code editor | System.ArgumentNullException: Value cannot be null. (Parameter ‘libraryPath’)
at System.ArgumentNullException.Throw(String paramName)
at System.Runtime.InteropServices.NativeLibrary.Load(String libraryPath)
at dotnetstart.DotNetInitialization.ImportResolver(String libraryName, Assembly assembly, Nullable1 searchPath) at dotnetstart.DotNetInitialization.ResolvingUnmanagedDll(Assembly asssembly, String name) at System.Runtime.Loader.AssemblyLoadContext.GetResolvedUnmanagedDll(Assembly assembly, String unmanagedDllName) at System.Runtime.Loader.AssemblyLoadContext.ResolveUnmanagedDllUsingEvent(String unmanagedDllName, Assembly assembly, IntPtr gchManagedAssemblyLoadContext) at Microsoft.Web.WebView2.Core.CoreWebView2Environment.GetAvailableCoreWebView2BrowserVersionString(String browserExecutableFolder, String& versionInfo) at Microsoft.Web.WebView2.Core.CoreWebView2Environment.GetAvailableBrowserVersionString(String browserExecutableFolder) at Eto.Wpf.Forms.Controls.WebView2Loader.Detect() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\WebView2Handler.cs:line 63 at Eto.Wpf.Forms.Controls.WebView2Loader.EnsureWebView2Runtime() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\WebView2Handler.cs:line 80 at Eto.Wpf.Forms.Controls.WebView2Handler..ctor() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\WebView2Handler.cs:line 405 at Ed.Eto.Wpf.EdHandler..ctor() at RhinoWindows.Runtime.EtoStyles.<>c.<Apply>b__0_7() at Eto.Widget..ctor() in D:\BuildAgent\work\dujour\src4\DotNetSDK\Eto\src\Eto\Widget.cs:line 308 at Eto.Forms.WebView..ctor() at Ed.Eto.Ed..ctor(EdOptions edOpts) at Ed.Eto.Ed..ctor(String languageId, String text, Boolean replaceTabsWithSpaces, Int32 tabSize, Boolean darkMode, Func4 getCompletions, Action`1 logger, Boolean disableContextMenu, Boolean disableSearchAndReplace, Boolean enableBreakpointSupport, String fileName, Boolean readOnly)
at RhinoCodeEditor.Editor.Panels.Codes.Previews.CodePreview…ctor()
at RhinoCodeEditor.Editor.Panels.Codes.CodeEditors…ctor(RCE rce)
at RhinoCodeEditor.Editor.Panels.CodesPanel…ctor(RCE rce)
at RhinoCodeEditor.Editor.RCE.InitLayout()
at RhinoCodeEditor.Editor.RCE…ctor(Window owner, CodeEditorLaunchOptions options, ILanguageLoadReporter reporter)
at RhinoCodeEditor.CodeEditor…ctor(Window owner, CodeEditorLaunchOptions options, ILanguageLoadReporter reporter)
at RhinoCodePlugin.Commands.ScriptEditorCommand.OpenEditor()
at RhinoCodePlugin.Commands.ScriptEditorCommand.EditScript()
Hi William -
