Hello, I just downloaded the trial copy of Rhino for mac 5.4.2, running on yosemite 10.10.5. Does GH run on the trial? typing explicityhistory gives “unknown command”.
thanks
M
thanks
M
Did you try typing Grasshopper? I’m not at my computer at the moment and can’t specifically remember if Grasshopper runs on Yosemite. It may require a newer operating system version (not sure so don’t take my word for that).
Also, if your trial version is expired then grasshopper won’t run.
I tried typing grasshopper…just to make sure -grasshopper comes preinstalled with the Rhino trial? this seems strange to me but I can’t find anywhere that just says where to download it for mac…
Hi Marcus-
I suspect there are two problems here…
First, you have likely not validated your license. Please run _ValidateLicense
and then Quit and relaunch Rhino. Grasshopper
should autocomplete, however…
Second, Grasshopper will not run on Yosemite. The command will autocomplete, but you should see a dialog that say that you will need El Capitan or better.
-Dan
