Gh Mouse_focus On Rhino
My custom pick logic always loses focus the first time. How do I [Set one Curve] like the default pick logic?
Code:
    public void GetRhobj()
        //IntPtr hwnd = RhinoApp.MainWindowHandle(); // Rhino_Win
        var Ge = new Rhino.Input.Custom.GetObject();
        Ge.SetCommandPrompt("选择一个物件");
        Grasshopper.Instances.DocumentEditor.WindowState = FormWindowState.Minimized;
        Grasshopper.Plugin.GH_PluginUtil.FocusOnRhino();
        Grasshopper.Plugin.GH_PluginUtil.BringRhinoToTop();
        // Ge.Get();
        Ge.GetMultiple(1, 0);
        var Id = Ge.Object(0).ObjectId;
        RhGuid = Id.ToString();
        RhinoApp.WriteLine(RhGuid, "选择的物件");
        Grasshopper.Instances.DocumentEditor.WindowState = FormWindowState.Normal;
I would avoid trying to manually force the focus with FocusOnRhino() / BringRhinoToTop() right before calling GetObject.
GetObject already runs Rhino’s native picking loop. If you change/minimize the Grasshopper window and immediately start the pick, you can easily get into a Windows/Rhino message-loop timing issue, which is probably why the first pick loses focus.
Also, this line does not mean “pick one object”:
In RhinoCommon, maximumNumber = 0 means “allow multiple objects and press Enter when done”.
For something like Rhino’s normal Set one Curve behavior, use either Get() or GetMultiple(1, 1).
