I’ve seen these error messages before for missing components.
In this case, I can open the .gh file in the Rhino8 app running on the AWS server, while logged in as RhinoComputeUser. The file is in the RhinoComputeUser’s Document folder.
However, when I hit the Rhino server itself for the exact same .gh file served by my middleware server, I get the Missing Definition Objects error.
Is there another possible explanation for these messages besides missing components.
(I have a mix of .gha componets and PackageManager components.)
Bill
Here are the log entries if that helps:
{"Timestamp":"2024-09-02T19:16:03.9669242+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:03.9786798+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:03.9965037+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:03.9976391+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.0088335+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.0100243+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.1079022+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.1089377+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.2456224+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.2514145+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.Exception: GH - Missing Definition Objects","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.5117412+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.NullReferenceException: Object reference not set to an instance of an object.\r\n at Pufferfish.Components.Components_Curve._5_Curve.BoundingRectangle.SolveInstance(IGH_DataAccess DA)\r\n at Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.5631560+00:00","Level":"Error","MessageTemplate":"An exception occurred while processing request","RenderedMessage":"An exception occurred while processing request","Exception":"System.NullReferenceException: Object reference not set to an instance of an object.\r\n at GhGltfConverter.glTfGhConverterComponent.SetMaterials(Gltf gltf, List`1 materialIndices, List`1 materialSpecs)\r\n at GhGltfConverter.glTfGhConverterComponent.SolveInstance(IGH_DataAccess DA)\r\n at Grasshopper.Kernel.GH_Component.Solution_Compute_MixedAccess(GH_StructureIterator it)","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.5659448+00:00","Level":"Error","MessageTemplate":"Expression generated an error for (startPt, base): Left hand value of operator α is Null: component \"Expression\" (8c77d191-053e-4aee-b5a2-bddaf23d074e)","RenderedMessage":"Expression generated an error for (startPt, base): Left hand value of operator α is Null: component \"Expression\" (8c77d191-053e-4aee-b5a2-bddaf23d074e)","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
{"Timestamp":"2024-09-02T19:16:04.5663365+00:00","Level":"Error","MessageTemplate":"Expression generated an error for (startPt, base): Left hand value of operator α is Null: component \"Expression\" (3094124e-3d14-4300-b76e-0ab66d9978a6)","RenderedMessage":"Expression generated an error for (startPt, base): Left hand value of operator α is Null: component \"Expression\" (3094124e-3d14-4300-b76e-0ab66d9978a6)","Properties":{"RequestId":"0HN6BGEMIEQEN:00000001","RequestPath":"/grasshopper","ConnectionId":"0HN6BGEMIEQEN"}}
