GH Hops install issue - update SDK
Built with newer SDK 7.4.21067.13000 but local SDK 7.2.210021.7001.
Instructed to close and reopen Rhino results in the same G Breakpoint error message over and over. How do I update SDK?
What version of Rhino do you have currently installed? Perhaps you need to update? If you type in “Options” in the Rhino command prompt, and then click on the Updates and Statistics item in the left hand menu, you should be able to see the currently installed version. If you want, you can set the Update Frequency to Service Release Candidate which will periodically check if there are new SR builds when you close Rhino. Or you can click the Check Now button to see if there are any new updates. Let us know if this resolves your issue.
