Hi David,
Here’s the new log:
Rhino : 8.34.26223.11002
Runtime : .NET 8.0.14
OS : Darwin 25.2.0 Darwin Kernel Version 25.2.0: Tue Nov 18 21:09:40 PST 2025; root:xnu-12377.61.12~1/RELEASE_ARM64_T6000
System.Drawing : /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/System.Drawing.Common.dll
Eto : /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/Eto.dll
GenericSansSerif → "Microsoft Sans Serif"
GenericMonospace → "Courier New"
GenericSerif → "Times New Roman"
CaptionFont → ".AppleSystemUIFont"
DefaultFont → ".AppleSystemUIFont"
InstalledFontCollection.Families → 1135 families
[189] Name is null ← this is probably the problem
sits between "Brush Script MT" and "BureauAgencyBold"
1 problem family/families found.
--- descriptor detail for the problem families ---
[188] Name = Brush Script MT
Dictionary = {
NSFontNameAttribute = "Brush Script MT";
CascadeList = CoreText.CTFontDescriptor
Languages = System.String
Features = CoreText.CTFontFeatures
FeatureSettings = CoreText.CTFontFeatureSettings
Enabled = False
[189] Name =
Dictionary = {
NSFontNameAttribute = "Brush Up";
Name = Brush Up
Enabled = False
[190] Name = BureauAgencyBold
Dictionary = {
NSFontNameAttribute = BureauAgencyBold;
Enabled = False
caption family name : .AppleSystemUIFont
found in enumeration : True
Eto.Fonts.AvailableFontFamilies → 1134 families
known to System.Drawing but not Eto : 1
.AppleSystemUIFont
known to Eto but not System.Drawing : 1
Brush Up
--- GH_FontServer's own defaults through ToEto ---
caption font detail:
asked : ".AppleSystemUIFont" 8pt Regular
S.D. : ".AppleSystemUIFont" 8pt bold=False italic=False
Eto : ".AppleSystemUIFont" family=".AppleSystemUIFont" 8pt bold=False italic=False
--- all 1134 installed families through ToEto ---
0 of 1134 families do not survive the round trip
Eto.Font(null, 8pt) THREW NullReferenceException: Object reference not set to an instance of an object.
GH_FontServer failed. Full text, including every inner exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
---> System.TypeInitializationException: The type initializer for 'Grasshopper.Kernel.GH_FontServer' threw an exception.
---> System.NullReferenceException: Object reference not set to an instance of an object.
at Grasshopper.Kernel.GH_FontServer.CreateFamily(String name) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/Grasshopper/Grasshopper/GH_FontServer.vb:line 68
at Grasshopper.Kernel.GH_FontServer..cctor() in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/Grasshopper/Grasshopper/GH_FontServer.vb:line 16
--- End of inner exception stack trace ---
at Grasshopper.Kernel.GH_FontServer.get_Standard() in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/Grasshopper/Grasshopper/GH_FontServer.vb:line 452
at System.RuntimeMethodHandle.InvokeMethod(Object target, Void** arguments, Signature sig, Boolean isConstructor)
at System.Reflection.MethodBaseInvoker.InvokeWithNoArgs(Object obj, BindingFlags invokeAttr)
at RhinoCodeScript.RunScript(IThisCode this, RunContext context) in file:///Users/jonathan/.rhinocode/stage/20sjpjde.sqw:line 333
--- inner ---
--- inner ---
Pasting it without a code block it looks like this (with weird square characters):
GenericSansSerif → “Microsoft Sans Serif”
GenericMonospace → “Courier New”
GenericSerif → “Times New Roman”
CaptionFont → “.AppleSystemUIFont”
DefaultFont → “.AppleSystemUIFont”
sits between “Brush Script MT” and “BureauAgencyBold”
-– descriptor detail for the problem families —
Dictionary = {
NSFontNameAttribute = “Brush Script MT”;
Enabled = False
[189] Name =
Dictionary = {
NSFontNameAttribute = “Brush Up”;
Name = Brush Up
Enabled = False
Dictionary = {
Enabled = False
.AppleSystemUIFont
Brush Up
-– GH_FontServer’s own defaults through ToEto —
asked : “.AppleSystemUIFont” 8pt Regular
S.D. : “.AppleSystemUIFont” 8pt bold=False italic=False
Eto : “.AppleSystemUIFont” family=“.AppleSystemUIFont” 8pt bold=False italic=False
-– all 1134 installed families through ToEto —
—> System.TypeInitializationException: The type initializer for ‘Grasshopper.Kernel.GH_FontServer’ threw an exception.
—> System.NullReferenceException: Object reference not set to an instance of an object.
— End of inner exception stack trace —
— inner —
— inner —
