Gh - Error!
I am not sure where this error comes from. At present, it does not affect the use of gh, but every time I open it, there is an error
The error tells that it tries to load the same assembly twice. It might be a library in use of Parakeet or Parakeet binaries itself (which might be referenced from another addin). Its also clear that it doesn’t break it, unless its the same or compatible version. But its still not good. Its a problem of plugin makers. You might need to remove one of the conflicting ones
See this thread Parakeet causing Grasshopper breakpoint after most recent Rhino 8 update
