New to Grasshopper, so I am tyring to get the GH_Document object from the opened GH document, but I am not sure what’s next to get the GH_Document object so that I can do something with it? Below is all I have and I don’t know what to do next:
Thank you very much. It seems that I run into the following error once I try to reproduce the code in that post: Message: 'ZuiPythonComponent' object has no attribute 'ClearPersistentData'
May I know how to feed input values to ‘ZuiPythonComponent’ objects?
A very simple .gh file that contains a python plugin module and the associated .py file is much appreciated.
EDIT 1:
Here is what I have in RhinoPythonEditor:
import Grasshopper
from Rhino import RhinoApp, RhinoDoc
from Rhino.Geometry import *
docServer = Grasshopper.GH_InstanceServer.DocumentServer
doc = docServer[0] # first opened document
def FindBatteryByNickname(docObjects, name):
if docObjects is None: return None
for obj in docObjects:
attr = obj.Attributes
if attr.PathName == name:
return obj
raise Exception(name + " was not found in document")
for obj in doc.Objects:
print attr.PathName
param = FindBatteryByNickname(doc.Objects, "Python (GhPython Script)")
pp = param.Params.Input[0]
pp.PersistentData.ClearData();
pp.PersistentData.Append(Grasshopper.Kernel.Types.GH_Number(5))
param.ExpireSolution(True);
doc = Grasshopper.Kernel.GH_Document()
doc.AddObject(param, False);
However, it seems that it does not work as nothing happens when I run the above script. May I know how to properly use it please?
Thank you
EDIT 2
UHH, I kinda figured out what was going on. Here is my script that is sort of in working conditions now. Still experimenting other features but I think this is what I expect.
import Grasshopper
#gh = RhinoApp.GetPlugInObject("Grasshopper")
#gh.LoadEditor()
#gh.CloseAllDocuments()
#gh.ShowEditor()
#gh.OpenDocument("z:\unnamed.ghx")
return obj
print attr.PathName
param = FindBatteryByNickname(doc.Objects, "input1")
print dir(param)
param.Script_ClearPersistentData()
param.AddPersistentData(85)
param = FindBatteryByNickname(doc.Objects, "output1")
results = param.VolatileData[0][0].Value
f = open("z://data2.txt", "w")
f.write( repr(results)) # str() converts to string
f.close()
