I’m trying to write code in Grasshopper. Could you please point to me to documentation of the function arguments, similar to RhinoCommons functions?
In R8, I no longer get the print out at the bottom of editor that tells me the function’s arguments, so I can only guess.
But now, I get this error, when the function ghpythonlib.parallel.run() (I think) is give correct arguments function without brackets, list of arguments, boolean (with default value)
Perhaps there is a new version of this function in a documentation, if it exists?
If you print the __doc__ attribute you should be able to see the definition and input and output of the function:
But I would also really like to get back the automatic help view in the bottom of the screen. @eirannejad is this something that will be implemented or that can be activated somehow?
I was not aware it was supposed to look like that, great! Nothing displayed in my editor, but apparently my Rhino 8 installation was not running automatic updates. After following the steps described here ( Rhino 7 options: update page ghosted again - Rhino / Rhino for Windows - McNeel Forum) I was able to update Rhino 8. After the update it looks exactly like you displayed, thanks a lot!
