关于gh电池包(cluster)得提问(Question about gh battery pack cluster )
我需要在电池包拿下来后,数值输入滑块也跟着在一起,有没有办法呢,希望得到解答,谢谢大家(I need the numerical input slider to follow after the battery pack is taken down. Is there any way? I hope to get an answer. Thank you all!)
That would be amazing! Unfortunately, it seems users can’t dynamically generate sliders at the same time they add custom components. However, Nautilus offers a similar behavior where adding a component creates associated sliders. I guess that behavior is pre-defined by the plugin’s author @laurent_delrieu.
I sincerely hope @DavidRutten would consider adding this function to GH1, or at least to Clusters. So, when you add a cluster, it will automatically create associated sliders. This will save time and make the workflow smoother.
Honeycam 2024-03-08 22-56-21
Yes it is defined in the plugin. I copied the behavior from Intrallatice InputTools.cs
I will try to find an option to disable enable them.
Thank you very much
