Gh Breakpoint ~ X doesn't quite mark the spot
The design intent is, that a frame—basically a square—contains lines that form an X-shape from the corners. I first tried this with two lines that spanned from corner to corner. The crossing in the middle was unhappy and so I provided the mid-point, with the aim of four struts going from each corner to the middle point.
While editing in the Cluster, everything looks fine. However.
What is odd, is that as soon as one comes out of editing the Cluster, one of the four lines disappears (?) and a Grasshopper Breakpoint warning says that one of the supplied items could not be converted.
I wonder if anyone knows what is going on and if there may be a workaround please?
I’ve attached the Gh & Rhino files ~
Grasshopper Breakpoint ! —.gh (23.2 KB)
Grasshopper Breakpoint ! —.3dm (4.0 MB)
Why this is happening I have no clue; But I fixed it by simply removing the current cluster output component and replacing it with a new one (again, no idea why this solves it, but there seems to be something wrong with this specific instance of the cluster output component).
Grasshopper Breakpoint_solved —.gh (26.3 KB)
Gijs, it works, thank you; it works.
