I generate some geometry from Grasshopperover and over again, but then (or course) my Bongo animation settings goes away. I would like to redo the Bongo setup as well from Grasshopper. Is that possible?
I tried something like this, but I don’t seem to be able to access Bongo:
Hm, and I’m only a Delphi/pascal guy… and never will the two meet.
What if Bongo would read, on demand, a “declarative” external data format for the joints & other definitions? Of course a “live API” would rock, but if Bongo could configure a model on demand from imported constraint declarations, it would be a significant first step in enabling the outer non-bongo space to communicate with Bongo.
Perhaps it would even suffice as a solution in most cases. Different ways to trigger Bongo to reconfigure according to such a descriptive file would be an API call (“reconfig”) or even a file modification in a dedicated file or subfolder would do (with a Bongo option set to “listener” state).
Somehow Bongo already stores the “declarative” information it currently makes use of, just add a step in which that info is inserted into the model by import, and off you go.
Q :
Which gives me the idea to ask if that stored info in the model is accessible (read/write) through the “regular” Rhino API, and if Bongo could be “paused” while modifying this info?
Well, I’m waiting, although not holding my breath.
Anyhow, since the problem of redefining the Bongo setup is biggest when generating/baking the model from Grasshopper (manually drawn models doesn’t change that much, and not so often), Bongo really needs to be accessible through the gh script components.
Q: So what is the plan? Will there be any option for reconstructing animation configurations from Grasshopper into generated models, or am I to forget any GH/Bongo integration thoughts altogether? I need to know what options to aim for.
I’m currently learning Rhino, Bongo, Grasshopper (since a few months) and also attempting to master them with Python/VBScript - I guess you can’t count on getting away with less than that (py/vb being essential in most software) - but I would prefer staying away from dot NET as to be able to get something useful done within a reasonable period of time as well as with a reasonable learning curve (relevant also as a marketing argument).
Bongo aside, I really don’t know what happened to Anders Hejlsberg. He started out well with Delphi but eventually got lost in the übercomplex dot net he… aven. Progress = simplifying things, not the other way around.
