ggEtabs modify section
Hey I’m trying to change my RC column section after the analysis and design part. I want to change section sizes and rerun the design without unlocking the model (just as in the Etabs change section option), but from GH so I can run a loop and can find an optimal cross-section. Somehow modify section plugin isn’t working, it doesn’t change my model sections.
Also the run design plugin reruns the whole analysis part(unlocking and rerunning the analysis).
Would really appreciate the help on this, could be a huge timesaver.
This should be possible. If you modify the model as you have set it up, then use an inline query component with the same design query you should get updated results with the updated design section. You do not need to add another design component.
