Hi all!
I’ve been playing along with the GG module and it’s been ok so far. I have some issues with positioning the door though.
- First for the door position, i don’t really know how to set the Location. If my wall is in a
YZ plan
, should i set the position parallel to this plan? When i try to do so (by building a plan with the origin and anx unit vector
) it returns weird things → Please see first screenshot. Seems to work better if i just set aplane normal to z
but then i can’t choose it to be along the right plane → Second screenshot. - I don’t really get how i can get the door to open on the right, or on the left. I have two possible options (
Position
inggIFC Door Panel Properties
orIFC Door Type Operation
inggIFC Door Type
). Should the result be visible as a panel visible on screen? Should it change with these options o do they only serve as metadata?
Thanks in advance for your help i’ve been quite confused.
Best
