Getting yak semantic version during runtime
I’m trying to get the semantic version of my plugin during runtime.
I’m defining the version in the .csproj as follows:
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
      <Version>1.0.0-alpha</Version>
  </PropertyGroup>
When I run yak spec the above version is correctly shown in the created manifest file.
However, I haven’t been able to get the version in code.
From what I’ve gathered the Version tag in .csproj files should be equivalent to the AssemblyInformationalVersionAttribute but when I try to read that:
Assembly.GetEntryAssembly().GetCustomAttribute<AssemblyInformationalVersionAttribute>().InformationalVersion
the GetEntryAssembly() method returns null
I have also tried getting the version through the Plugin.Version property but that returns 1.0.0.0 and not the desired 1.0.0-alpha
I think you want GetExecutingAssemly() instead of GetEntryAssembly().
You could also try System.Diagnostics.FileVersionInfo.GetVersionInfo(System.Reflection.Assembly.GetExecutingAssembly().Location).ProductVersion.
did the trick!
