Getting surfaces in to AutoCAD
I’ve got a client who still uses AutoCAD, or more specifically a vertical application for their customers built with it.
They claim to have to do a lot of clean up on what I send them because any geometry that’s not a closed solid in the DWG comes in as what they tell me (this is all second- or third-hand of course, joys of a large company) is a mesh. They’re definitely surfaces in the export file.
While it’s not that hard to satisfy this arbitrary requirement I’m hoping there is just some import option setting to avoid this pointless busywork, after 5 years of another group complaining about Inventor not liking surfaces I was able to tell them oh just change the import settings to such-and-such… Using a different format would work fine too…
Hi Jim
Could you please share this such-and-such, as I hear exact same complaints from my guys.
Can you send me an example and I can test it. We can figure out what works best.
Inventor I.expect was a little more forgiving.
Are you also trying to get into autocad?
Been doing surface imports into Inventor for years without issue…stp and iges.
It may not be an issue of Rhino-Inventor relations but rather the problem of a closed Rhino model still being interpreted as a bunch of surfaces (by our machines), therefore Rhino models needs to be rebuilt in Inventor.
I have made the step exporter for them to test. I can also ask for more details.
Sorry shouldn’t have mentioned Inventor that’s unrelated, it’s just AutoCAD we’re trying to get surfaces in to.
open objects.3dm (4.6 MB)
Here’s an example Rhino file, it’s just literally any not-closed objects…
If using IGES or step is more reliable that’s okay, but I’d like to see if DWG can work since I don’t want to have to maintain libraries of multiple file types…and these vertical apps can be so obnoxiously quirky that sending STEP might solve one problem and cause three…
Sorry guys should not have brought up Inventor, that was a thing where Inventor literally would only bring in closed objects because the import options said to only import closed objects.
Which vertical apps? We do have rhino.inside.auticad and rhino.inside.civil3d that can bypass file format.
So here is the result of a 2018 style DWG, but making sure the Export Surface property is set to Solids:
Does that seem better?
open objects.dwg (114.4 KB)
Thanks Scott, I’ll try it tomorrow…is it possible they have some import setting in AutoCAD that is set to import surfaces as meshes, is that even possible?
I am not sure why you would want that?
We try to import the best geometry possible. Then mesh from there. It would be possible to make a script that meshes surfaces immediately after import.
I don’t want that, nobody wants that, I’m just trying to figure out where the issue could possibly be coming from. Is there a setting in AutoCAD to import surfaces as meshes?
I’ll try the different DWG version but I’ve always used the export surfaces as Solids option, just much older AutoCAD versions, so…we’ll see tomorrow!
Oh, I expect the defaults in the DWG default schemes export meshes from Rhino. The setting I am showing is not the default.
No I’ve always changed that, the surfaces are never actually meshes in the DWGs…
Well let’s keep experimenting and see what we can figure out. We can keep working thru examples you have and test in both apps?
I’ve dealt with similar problems in the past. Rather than exporting a DWG from Rhino, just export/save the surfaces to standard Rhino-3DM. Then use the AutoCAD built-in 3DM importer.
Please be aware that some vertical AutoCAD products might not have the 3DM importer.
I know this doesn’t solve the actual issue, sorry.
I mean the solution is to replace the antiquated LT-based configurator with a Rhino-based solution, but for today…
Plot twist, the person who actually works with these files is out for the week, so we’ll be in suspense for a bit…
No question that older Autocad platform will be much worse at supporting 3d surfaces and solids.
