I have created a new Topic to help debug this issue!
@Tom_Norris The current block insertion functionality is still quite limited. My idea is: for newly created blocks, you should be able to edit their attributes and parameters before baking, with real-time preview. Once everything looks right, you then perform the final bake.
does autocad architecture work? or just the regular autocad?
Unfortunately the attributes and properties are not available in AutoCAD until after the block reference is create in the database.
To address the baking suggestion we need to delve into why some objects are bakeable and others are not. There are two kinds of objects in RiA : Database objects and Geometry objects. We treat them differently: the geometry we keep wherever possible tightly coupled to the Rhino Geometry counterparts. They use the grasshopper Geometry Goo as this has the benefit of allowing grasshopper transformations and morphs, even if they will eventually become AutoCAD database objects - It makes sense to keep these tightly coupled as we want to be able to switch between the Rhino and AutoCAD types on demand. These are the objects which can be baked and when they are backed they are added to the AutoCAD database.
Then there are the purely AutoCAD database objects like Layers, LineType and Block Definitions. These exist as objects isolated from their Rhino counterparts as a logical distinction, and they require an active database transaction to be created and are immediately added the database and so they do not any need for the baking functionality.
Block References then fall into a grey area, whilst they have a do have a geometry component it would not make sense to couple them to the Rhino block infrastructure as they need the AutoCAD Block definitions and database to be created, which is why they are currently in the second category and are created immediately. If we did consider making them bakeable so they are not added to the database until they are baked. This would not have the effect you are after as there attributes/ parameters would not be available until after they are created in the database. So all you would have is the default geometry from the block definition available to be previewed. It also would add a number of complications, as it would require making them Geometric Goo, which would allow some invalid operations.
We can have a think about ways to improve the infrastructure so it is less limited.
@Lawand_Noa_man we have not tested it on AutoCAD Architecture, but there should be no reason why it cannot, if you do have any issues, let us know and we can look to resolve them as we may need to update the package configuration to make sure AutoCAD loads it - but it also may just work out of the box.
Great I’ll give it a try and let yall know
where do I download/ install rhino-inside-autocad
see the first post in this thread for additional details.
I am very exited about Rhino.Inside.AutoCAD! as many of our work is done in AutoCAD. The highlight preview of selected elements would be a great feature!
When it comes to adding or changing a drawing, is it possible to get all object/blocks in a layer and then move these objects/blocks to a different already existing layer?
We mostly work by adding or removing existing parts of a drawing, and it is very rare to start with an empty sheet. What would then be useful blocks for selecting objects and removing or adding to an existing drawing? I have been playing around, but could not find how to do this.
Hello, there. Is there any way to retrive the element properties? like layer, lightweight, and etc? just like Rhino inside revit, you can access element parameter. I am trying to transfer the autocad" polyline to Rhino with its own layer.Thank you!
edit: I find a way to fliter by layer name and I am thinking maybe I can use Elefront to bake geometry with its layer.
Hi @LOKI1
Yeah that sounds like it would be a useful component to have, ive added it to the road map here:
Thanks for the feedback, it is really useful!
We have now added this starting in version V1.0.19
This is currently possible using the filter components:
This is also sort of currently possible but we are still working on the documentation side of the project so these slightly more convoluted ways of doing things are not so obvious. But for context:
The geometry objects in Autocad when in the grasshopper canvas are much more similar to Rhino geometry in Grasshopper than the Rhino Inside Revit approach. We can do this is because they have a direct geometry conversion type within Rhino (which the RiR types does not). This means they are on memory, geometry only (no properties) and do not exist in the Autocad Database until a Bake operation is performed. It is through the baking which you can set the layer of the geometry:
Blocks on the other hand are different. They always exist in the AutoCAD database they are not bakeable and currently there is no way to edit there properties - This is something we need to add - I am hoping to squeeze into V1.0.20
Adding geometry to layouts is defiantly something we want to expose in the future. You can follow the ticket here: Add support to bake objects into the Layouts · Issue #28 · mcneel/rhino.inside-autocad · GitHub
Yesterday Rhino.Inside.AutoCAD saved our lives..
We recieved a very big and messy autocad file, thousands of blocks and groups and object and for some reason we wanted every object to be on layer “00” even object inside of blocks and groups.
AutoLISP did nothing, importing it into rhino messed up the file and it was painfully slow. Rhino inside Autocad came in clutch.
C# SCRIPT.txt (4.4 KB)
Main.gh (6.8 KB)
@Tom_Norris
Operations performed using Rhino.Inside.AutoCAD generate a long sequence of operation history records in AutoCAD. Is it possible to package each operation as a single grouped unit, similar to Rhino.Inside.Revit?
@Tom_Norris
When I connect a CAD block to the AC-BlkRef component, if no color is input, the block’s color is forcibly changed to 0,0,0. This is unreasonable; in this case, the block’s original color should be preserved.
Hi Pan, Yeah someone else had also noted this, in the next release candidate the default has been updated to now ByLayer, would that work in your opinion? You can follow this issue: Block Reference Color · Issue #29 · mcneel/rhino.inside-autocad · GitHub
I will need to have a think about this, there are some key difference in the way RiR handles the revit transactions and we handle the RiA transactions. But potentially there are things we can do to group some of them together. What sort of operations were you doing?
For any operation, as long as multiple elements are involved in the same operation, each element leaves its own operation record. This is disastrous for undoability. I want each operation to be recorded only once, regardless of how many elements are bound.
Hi All,
Version V1.3.1 is now available for testing, this is largest update since the introduction of Civil 3D, and adds support for AutoCAD 2027 and Rhino 9.
We have also added a significant update to Baking, both with the original Bake component and a new Tracked bake component.
In case you missed it we now have an extensive Getting started Guide on our Doc site, which is a great resource for those who want a more guided user experience set up with Rhino Inside AutoCAD or Civil 3d:
V1.3.0 Full Release Notes
- This version introduces updates to the existing Baking Component which will require it to be rewired hence the minor version number jump.
- Includes a new Visual update to Tracking Components so they are clearly distinct and show when they are tracking objects.
- Update to the create block reference component. Where previously it accepted a list of insertion points and if the user wanted to set another input (e.g. rotation) to each point they would have to graft both inputs , now all the inputs are lists and the component will match where it can and inform where it can not.
- Bug fixed in the preview material - where changing document before the document active event fires caused a erased id error.
- Original Bake component updated to contain a Bake button mode, activated by the right click menu.
- New Tracked Bake Component which will take the object is creates, this follows the same patten as the other tracking components.
- Brep baking was also updated to batch multiple breps in each import and export cycle - which results in a significantly faster result.
- Get List components all updated to default to a Stale tacking mode. In this mode the user will be informed that data is stale (pale blue) and are presented with a refresh button. This prevents and feedback loops caused by the previous auto update. Auto - update mode is still available on right click, but it is not the default.
- Rhino 9 support. Rhino.Inside.AutoCAD was hard-wired to Rhino 8 via a single registry key. It now enumerates the installed Rhino versions and picks one: with a single install
nothing changes, and with more than one you’re asked which to use, with an “always use” option that’s remembered. .NET 8 builds host Rhino 8 and 9; .NET Framework 4.8 builds
host Rhino 8 only. Your choice is saved to %APPDATA%\Bimorph\RhinoInsideAutoCAD\UserSettings.json. If no hostable version is found the commands now report why instead of failing
obscurely. - Fixed the AutoCAD and Civil tabs not appearing in Grasshopper under Rhino 9. Rhino 9 changed how component libraries are loaded and rejected ours because they ship as .dll, so
the canvas opened with both tabs missing. Also fixed the component libraries being re-registered on every canvas creation, and the Civil library failing to load once the main
library had registered. - Preview colours are now user-configurable. The Rhino, Grasshopper and selected preview colours were fixed values; they can now be chosen from the full 1–255 AutoCAD Color
Index palette on the settings page of the support dialog, and apply to previews on screen immediately. Existing settings files keep the previous colours. - Fixed changed preview colours not reaching shaded previews. The material was cached under a fixed name, so a colour change was ignored once a material already existed.
- Fixed on-canvas buttons retaining mouse capture. If a button was hidden part-way through a click — by toggling Driven Button or Auto Update from the right-click menu between
pressing and releasing — the component could keep the capture. Affected the Bake and Query buttons. - The Bake, Query and Refresh buttons are now one shared canvas button model rather than three near-identical copies, so they stay visually and behaviourally consistent as more
are added. - Serialization keys, menu labels, tooltips and on-canvas messages moved into shared constants classes. Persisted key values are unchanged, so Grasshopper files saved with
earlier builds continue to load correctly. - Added a .gitattributes to settle the repository’s CRLF/LF handling.
- Adds support for AutoCAD 2027
- Adds NET 10 framework builds
V1.3.1 Release Notes
- Updates the installer and pipeline to fix bugs
GH_Load_Ex.txt (1.4 KB)
Thank you for developing such a fantastic tool.
I have installed it, but an error occurs when launching Grasshopper. I have attached the error text.
Additionally, the packages that are supposed to load when launching Grasshopper (after starting Rhino normally) failed to load.
The software versions I am using are as follows:
・Civil 3D 2026.2.2
・Rhino 8
