Getting script call behavior via API call
I’m just beginning with Rhino and plugin development, so this might be obvious but I can’t figure it out.
I can import a file by using RunScript and skip over the scaling prompt by passing the _Enter parameter.
var result = RhinoApp.RunScript($"_-import “{filePath}” _Enter", true);
However if I try to import using the API call on the document the prompt always shows up in the command area and requires keyboard input before the plugin will continue.
doc.Import(filePath);
I’m wondering if there is some property on the RhinoDoc that I need to set to avoid the prompt?
Thanks, Patrick
Hi @user882,
Can you provide a working sample, that we can run here, that isn’t working for you?
– Dale
