Getting random in accurate dimension lines in Rhino 8
Hi All,
Recently, i’ve experienced a few glitches in dimensions (_Dim).
I recently did a drawing set and in Layout space, one of the Dims was 1” off. it wasn’t snapping weird, just happened. I deleted it and reshot, then it was fine. So i didn’t think much of it.
I just experienced it again. i have two dims in the is model, on Distance, the gap is 2.03”, equal. but one dimension shows 2” and another says 2-1/16th. Both should be the same.
i’m not talking about resolution, i understand it’s supposed to round down. but the fact that they’re not rounding the same seems to be an issue, similar to what i experience in another file on layout.
dimesion line accuracy issue.3dm (3.4 MB)
Hi Louis,
There is a slight difference that is just enough to trigger the rounding.
thanks! something must have moved on my end!
