I’m trying to create a definition that takes all the members of a reciprocal roof and does a Boolean split (or diff) with the previous or next member in the list using the Anemone loop commands. I have not succeeded so far. Can anyone help?
I want to make a difference or a notch in each strut using the neighbouring strut, not a union… If there’s a way to do this without making a loop, then I would like to know also…
But the shape I want is dependent on the angle and orientation of the already polar arrayed objects, hence why I need to do the Boolean difference after having created the polar array.
in your definition you have 10 objects if you want change the number that’s easy and polar array the new shape again
you can use rotation with chosen center and split than polar array based on the rotation angle
