Getting invalid breps with rail revolution
Hello everyone,
I am getting some invalid breps when doing rail revolution and cannot figure out why is this happening. As the image show, some of them were not made.
Rect fillet slds doubt.gh (24.1 KB)
The rail ends don’t match the section endpoint.
What’s the benefit of using rail revolve at all? Why not extrude taper or loft two rectangles?
I did the revolution because I need the fillet on the upper side of the box
The fillet operation for some reason fails. I have no idea why.
Because of what you said that the rails are not matching, I am trying to make the curves match to one guide, tried with flip curve/guide, but unsuccessfully.
I matched the rail curve end, but it didn’t succeeded
I think if your profile end at mid edge, the seam should be there.
But it still fails on the same curves
Here we see why the fillets fail in Grasshopper:
Using offset instead of scaling to create the tapered boxes results in the same slope angle all around the boxes and the fillets have the same width.
Rect fillet slds offset slope taper.gh (16.1 KB)
