I’m currently programming a Conduit and I would like to get the Field Of View of the current RhinoViewport I am rendering into.
A RhinoViewport does supply the “Camera35mmLensLength” property, which seemed to be a constant value of 49.9999, which was too big to be the field of view. The field of view seemed to be closer to about 28.0.
Searching through the forum I found this post:
The post is quite old and the links in it are broken, so I was unable to determine what they were suggesting.
I also found this: https://wiki.mcneel.com/rhino/rhinolensing
But that article is aimed towards setting up a new lens, and I was unable to use it to get the information I needed.
My question is: how can I get, or calculate, the field of view of a given viewport while inside a Conduit? Is it possible?
var view = doc.Views.ActiveView;
if (null != view)
var vpinfo = new ViewportInfo(view.ActiveViewport);
if (vpinfo.GetCameraAngles(
out double halfDiagonalAngleRadians,
out double halfVerticalAngleRadians,
out double halfHorizontalAngleRadians)
// TODO...
Nice work, @dale that worked well for me!
I had to do a little more math:
if (null != view)
var verticalAngle = 2.0d * halfVerticalAngle;
fieldOfView = (verticalAngle * 180.0d) / Math.PI;
Which works perfectly - as I size up or down the Lens Length in the Viewport’s settings, my fieldOfView now changes appropriately!
Thanks for the help, Dale!
