Make 2d isn’t working appropriately for this model. I don’t get inside network curves for this object.
SAMPLE FILE_MESH MAKE 2D.3dm (2.8 MB)
Following is the type of drawing that I require. The dotted lines’ colour I’ve changed in Illustrator.
Make2D only uses mesh wires on unwelded edges. If you want the whole mesh structure, run the Unweld command on it with a value of 0. You should then get all the mesh edges.
Thanks! That worked!
