G’day everyone,
Fair cop, I’m trying to translate/pilfer Dale Fugier’s steel section script from rhinoscript to rhinopython.
But GetSettings is giving me grief.
import scriptcontext
import Rhino
# Draws Flat Bar sections
def FlatBars():
cmdname="Flat Bar"
configfile="AllySections.ini"
section="FLAT_BAR"
filename=rs.FindFile(configfile)
if not filename:
msg=("Unable to locate " + configfile + ".")
rs.MessageBox(msg, 16, cmdname)
return
entries=rs.GetSettings(filename, section)
if not entries: return
entries=rs.GetSettings(filename,section) keeps giving the errors
"No section: ‘flat_bar’ "
Yet the ini file has this on the first line…
[FLAT_BAR]
50x6 = 50.0,6.0
The help file sugggests there should be no issues with case sensitivity, but I have them as all caps anyway.
In SaveSettings there’s talk of a windows cache keeping the most recently accessed file around. Could this be the problem? If I delete the ini file it cannot be found, so don’t think this is the problem.
Any other thoughts?
cheers,
Nick
