GetObject selects SubD Objects when filtered for Brep still selects SubD
When using GetObject with a filter set to select only Breps GetObject will still select SubD objects.
Is this intentional, if so how do I filter for breps and breps alone?
Code to reproduce:
// #! csharp
using System;
using Rhino.Geometry;
using Rhino.Input.Custom;
using Rhino.DocObjects;
GetObject getObject = new GetObject()
    GeometryFilter = ObjectType.Brep
getObject.GetMultiple(0,1);
Hi @Cristopher_Russ,
Yes. If the object can be converted to the filter type it will be selected.
Something like this should work:
// #! csharp
using System;
using Rhino;
using Rhino.Commands;
using Rhino.Input;
var test = new Test();
test.Main();
public class Test
    public void Main()
        GetObject go = new GetObject();
        go.SetCommandPrompt("Select surface or polysurface");
        go.SetCustomGeometryFilter((obj, geometry, ci) =>
            return geometry is Surface || geometry is Brep;
        go.Get();
        if (go.CommandResult() != Result.Success)
            return;
        // TODO...
– Dale
Hey Dale,
Thanks for answering, your solution works great.
