Let’s say we have created a routine that takes a curve and cuts it in 3 equal segments and assigns to those segments a name, i.e Segment1, Segment2, Segment3.
Now I want to use the Rhino GetObject class in order to be able to select one of those segments. Any ideas?
Yes Dale thanks for the reply. I’ve been working on this lately.
The real question though is how can I treat assets that do not belong to the GetBaseClass, getObject Classes etc.
Example: If I have drawn curves, or points, or other entities/assets which are Rhino objects, the above mentioned classes can be applied on them, e.g.:
public static Result GetUUID(RhinoDoc doc)
ObjRef obj_ref;
var rc = RhinoGet.GetOneObject("Select object", false, **ObjectType**.AnyObject, out obj_ref);
if (rc != Result.Success)
return rc;
if (obj_ref == null)
return Result.Nothing;
var uuid = obj_ref.ObjectId;
RhinoApp.WriteLine("The object's unique id is {0}", uuid.ToString());
return Result.Success;
But what if someone has created Classes which construct objects that do not belong to Rhino, i.e., which don’t listen to the ObjectType Class? Is there a way to make these objects to be treated as Rhino Objects, and be able to use all the Get Methods on/with them?
Not a specific problem. I was trying to figure out if it is possible to create new objects/classes and make them inherit from RhinoObject. You know, to see if one can interfere with Rhino classes and the way they inherit one from another.
