GetNumber() with toggle option like Circle radius/diameter
Hi all,
Looking for a smaple of how to program RhinoCommon GetNumber with a single toggle option like the Rhino command Circle has for Diameter./Radius. I know how to do this with AddOptionToggle, but it doesn’t qork quite the same way with the command-line prompts - which is what I want to figure out.
The Rhino command looks like this:
Radius <10.000> ( Diameter ...) (there are other toggles)
if you hit the “Diameter” link, it changes to “Radius”, the prompt changes to “Diameter”, and the default number doubles:
Diameter <20.000> ( Radius...)
With what I can program currently - according to various samples here and there - I always end up having something like this:
Current Value <10.000> (Value=Diameter)
The “Current Value” prompt doesn’t change and I always have the toggle that reads Value=Diameter (or Radius), whereas I would like to just have “Diameter” or “Radius” without the “Something=” part.
Thanks, --Mitch
Hi Mitch
What about this ?
def main():
  rad = 50
  radius = True
  while True:
    scriptcontext.escape_test()
    gen = Rhino.Input.Custom.GetNumber()
    gen.AcceptNothing( True )
    if radius:
      gen.SetCommandPrompt( 'Radius <%g>' % rad )
    else:
      gen.SetCommandPrompt( 'Diameter <%g>' % ( rad * 2 ) )
    # add option
    if radius:
      optind = gen.AddOption( 'Diameter' )
    else:
      optind = gen.AddOption( 'Radius' )
    # get input
    gen.Get()
    res = gen.Result()
    if res == Rhino.Input.GetResult.Cancel:
      return
    elif res == Rhino.Input.GetResult.Nothing:
      break
    elif res == Rhino.Input.GetResult.Option:
      radius = not radius
    elif res == Rhino.Input.GetResult.Number:
      num = gen.Number()
      print 'Number = %g' % num
      return
main()
Well … it does not use a toggle option, it’s just built using ‘low level’ code, so to speak.
I often like building inputs this way in my scripts, it’s very flexible and even lets you do things beyond (or simply different from) what regular Rhino commands do.
HTH Cheers
Hey, thanks for the example Emilio… I always tend to forget the fact that you can work with string options when all else fails…
Cheers and happy holidays, --Mitch
Thank you, Mitch.
Merry Christmas !
Hi Mitch,
Here is an alternative to working with strings:
import Rhino
def GetRadius(radius):
    radius_mode = True
    gn = Rhino.Input.Custom.GetNumber()
    gn.SetLowerLimit(0.0, True)
    gn.AcceptNothing(True)
    while True:
        gn.ClearCommandOptions()
        if radius_mode:
            gn.SetCommandPrompt("Radius")
            gn.SetDefaultNumber(radius)
            gn.AddOption("Diameter")
        else:
            gn.SetCommandPrompt("Diameter")
            gn.SetDefaultNumber(radius * 2.0)
            gn.AddOption("Radius")
        res = gn.Get()
            radius_mode = not radius_mode
            continue
            return radius
        elif res != Rhino.Input.GetResult.Number:
            return Rhino.RhinoMath.UnsetValue
        value = gn.Number()
        if radius_mode:
            return value
        return value * 0.5
radius = GetRadius(50.0)
if Rhino.RhinoMath.IsValidDouble(radius):
    print radius
Cool, thanks Dale! --Mitch
