Wrote this code to take in two parallel lists/trees such that
x = [1,2,1]
and
y = [[p1,p2,p3,p4,p5,p6],[pt1,pt2,pt3,pt4,pt5,pt6], [pn1,pn2,pn3,pn4,pn5,pn6]]
after placing through the data tree to list converter, but when I run my code, I receive the error:
Runtime error (ArgumentTypeException): getitem() takes exactly 2 arguments (1 given)
Traceback:
line 32, in script
def tree_to_list(input, retrieve_base = lambda x: x[0]):
"""Returns a list representation of a Grasshopper DataTree"""
def extend_at(path, index, simple_input, rest_list):
target = path[index]
if len(rest_list) <= target: rest_list.extend([None]*(target-len(rest_list)+1))
if index == path.Length - 1:
rest_list[target] = list(simple_input)
else:
if rest_list[target] is None: rest_list[target] = []
extend_at(path, index+1, simple_input, rest_list[target])
all = []
for i in range(input.BranchCount):
path = input.Path(i)
extend_at(path, 0, input.Branch(path), all)
return retrieve_base(all)
pts = tree_to_list(y)
ptList = []
for i, numb in enumerate(x):
if numb == 1:
ptList.append(y[i][0])
elif numb == 2:
ptList.append(y[i][-1])
