I found that the GetGeneratingElements() method in the python component asks for two arguments but within the ApiDoc it’s only asking for one. I’m not sure what that new first argument is asking for. (self: Element) Can anyone help me? Thank you
Seems like you haven’t closed the parentheses on method call line 38?
You only need to pass one argument to this method. What you’re highlighting on the API docs shows the object type and a variable which are essentially one argument.
Well I didn’t finish that line. But upon typing in the argument the system tells me that this method takes exactly 2 arguments.
You’re calling the method like it’s static. You need an element reference to call this method on.
For example if ‘wall’ is your element then you should call it like:
wall.GetGeneratingElementIds(face)
See the example here at the bottom of the page:
https://www.revitapidocs.com/2019/112590d2-de20-dd1f-ae05-df7dfb3b410f.htm
