This Rhinoscript code will hang a while
Dim arrEdges
arrEdges = Rhino.GetEdgeCurves(,,, True)
rhino.command "_ProjectToCPlane _Yes"
Is there a better route ?
Thx,
Keith
Dim arrEdges
Thx,
Keith
Hmm, that seems odd, if I run that here on a couple edges of a simple box, I get the BOX deforming along with the projected edges. It’s almost as if the edges of the box itself are internally selected along with the duplicated edge curves. Maybe that’s why Rhino is hanging on you?
This seemed to work without deforming the box:
Dim arrEdges
Call Rhino.GetEdgeCurves(,,, True)
Rhino.Command "HistoryPurge All"
Rhino.Command "SelLast"
Rhino.command "_ProjectToCPlane _Yes"
or a slightly more rhinoscripty version
Call Main()
Sub Main()
Dim arrEdges,plane,xform
arrEdges = Rhino.SelectedObjects()
If IsArray(arrEdges) Then
plane = Rhino.ViewCPlane()
xform = Rhino.XformPlanarProjection(plane)
Call Rhino.TransformObjects(arrEdges, xform, False)
End If
End Sub
But that’s just a hack workaround for what looks like a bug…
@dale ?
–Mitch
Thanks for your time Mitch, that is a great help.
Keith
