Hi guys, (@pascal) I am trying to get a point’s world coordinates by picking it on a detail.
I found a way to get a point, check if it is within a detail, get the details PageToWorldTransform, but then I got stuck on how to use that to convert the point. (It returns “None”)
What am I missing? Or is there an even easier way to do this in Python?
(Everything works fine down to the last annotation, it is the point.Transform(xform) that doesn’t return any results)
### Get World point from Detail.py
### WIP by Holo 2024
import Rhino
import scriptcontext as sc
def runScript():
### Check if in a Layout
view = rs.CurrentView()
if not rs.IsLayout(view):
print ("This is not a Layout")
return
### Check if details in Layout
details = []
objs = rs.VisibleObjects()
for obj in objs:
if rs.IsDetail(view, obj):
details.append(obj)
if len(details)==0:
print ("No details are visible")
return
### Get point
point = rs.GetPoint("")
### Check if point is within any details
detail = None
for test_detail in details:
bbox = rs.BoundingBox(test_detail)
if point.X > bbox[0][0] and point.X < bbox[1][0]:
if point.Y > bbox[0][1] and point.Y < bbox[3][1]:
detail = test_detail
break
if detail == None:
print ("No details contained the point")
return
print ("The point is within detail:", detail)
### Get detail Page to World Xform
detail = sc.doc.Objects.Find(detail)
xform = detail.PageToWorldTransform
worldPoint = point.Transform(xform)
print worldPoint
runScript()
