Get used InstanceDefinition for a InstanceDefinition
Hi all,
is there a way to get the whole InstanceDefinitions for a block and there coresponding structure.
The method InstanceDefinition.GetContainers return a list of all the InstanceDefinitions that contain a reference of this InstanceDefinition.
This means a nested InstanceDefinition lists all InstanceDefinition that use this InstanceDefinition but the top level InstanceDefinition that use all this referenced InstanceDefinition return a empty array if the InstanceDefinition.GetContainers is used.
What i want is a top to bottom structure of the InstanceDefinitions not the other way.
Maybe i could inverse the GetConatiner array but befor i can do so i need to compare all these arrays for similar InstanceDefinitionObjects.
Ideas are welcome.
HI @flokart ,
This would be one way to get a List of all nested InstanceDefinitions inside a parent definition (irrespective of their nesting order)
public List<InstanceDefinition> GetInternalDefinitions(InstanceDefinition iDef)
            var internalObjects = iDef.GetObjects();
            List<InstanceDefinition> internalDefs = new List<InstanceDefinition>();
            foreach (RhinoObject rObj in internalObjects)
                if (rObj is InstanceObject iObj)
                    if (!internalDefs.Contains(iObj.InstanceDefinition))
                        internalDefs.Add(iObj.InstanceDefinition);
                        foreach (InstanceDefinition subDef in GetInternalDefinitions(iObj.InstanceDefinition))
                            if (!internalDefs.Contains(subDef))
                                internalDefs.Add(subDef);
            return internalDefs;
