Get the Name of Objects in an Object list
Hi Forum,
I currently stuck a little bit. I have a collection of Meshes. I want to join all meshes with the same Name.
But i dont understand the objectnames function:
https://developer.rhino3d.com/api/rhinoscript/object_methods/objectnames.htm
What did i do wrong? Thank you!
import Rhino
meshes = rs.ObjectsByType(32)
arrname = Rhino.ObjectNames(meshes)
print(arrname)
This is the Error i keep getting:
Message: ‘Rhino’ object has no attribute ‘ObjectNames’
You are mixing VB Rhinoscript and Python Rhinoscriptsyntax…
Maybe this will help:
https://developer.rhino3d.com/api/RhinoScriptSyntax/#selection-ObjectsByName
Or, to have the equivalent of vb Rhino.ObjectNames():
all_names=[rs.ObjectName(obj) for obj in objs]
(where objs is your list of objects to check)
Very helpfull! Thank you very much!
The code is not very sophisticated but cleans the user mess. so its helpfull. Maybe it helps people who google the issue.
# Packe alle NetzID in eine Liste
#fuege Netze mit gleichen Namen zusammen
all_names=[rs.ObjectName(obj) for obj in meshes]
for name in all_names:
    rs.Command("_-Selname " + name + " _join _enter _Selnone")
