I have a data tree that contains a series of branches. I would like to recieve only 1 branch then multiple branches have the same value (the green dot). The branches to be removed is based on the size of another value (the red dot). I would like only to recieve the branch where the “red dot” has the lowest value.
i.e.
There is 3 branches with the value 4.6. The branches with the values 84028 and 98637 should be removed as they are larger than 70588.
Here is and example of how the branches are created.
Each branch are basically just a list of numeric values for each “design”.
(The values in the example are different, but the princip is the same).
Okay, I have tried to make a new example without Karamba.
The tree i still a collection of branches (one branch for each “design”).
I would like to kind of group all the branches that have the same value in {0;i}(0) and get the branch from each group that has the lowest value based on {0;i}(1).
