Hello!
Is it possible get this sizes from python code?
Thank you!
Hi @akushnir,
if your picture is showing a set of UV-unwrapped meshes the dimensions marked in red depend on the UV-Rectangle you’ve picked. You could get the dimensions by creating a bounding box with rs.BoundingBox()
and measuring the returned point distances. Example:
def DoSomething():
# get uv meshes
mesh_ids = rs.GetObjects("Select UV-Islands", 32, True, True, False)
if not mesh_ids: return
# get width and height from bounding box
bbox = rs.BoundingBox(mesh_ids)
if bbox:
w = rs.Distance(bbox[0], bbox[1])
h = rs.Distance(bbox[1], bbox[2])
print "W={} H={}".format(w,h)
DoSomething()
Does that help ?
_
c.
