How I can get/set user text on c#??
Python sample:
rs.SetDocumentUserText(“var1”,“test”)
a=rs.SetDocumentUserText(“var1”)
Thanks
Python sample:
Thanks
Document text is stored in the RhinoDoc.Strings table
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_RhinoDoc_Strings.htm
Object Attribute Text is located in a RhinoObjects ObjectAttributes
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_DocObjects_ObjectAttributes_GetUserString.htm
Here’s a link to the original User Text / Doc Text panel project. It should give you plenty of ideas and examples
Hello @Trav ,
Can you write a simple comand to set an get the user text?
Sorry but , I using python and trying use some C# comands with python, so , the c# is just for Dock panel.
Thanks
Sorry , @Trav I can not understand this C # syntax, it must be because I am, very attached to python syntax.
So , I have two C# buttons, and I whant set a user text on doc, and get user text from doc,
How can I do this easily? following this example?
private void button1_Click(object sender, EventArgs e)
// equivalent to
rs.SetDocumentUserText(“var1”,“test”)"
private void button2_Click(object sender, EventArgs e)
// equivalent to
String a = rs.GetDocumentUserText(“var1”)
MessageBox.Show(a.ToString());
Thanks
To use RhinoScript from inside of your button you’ll need to add a reference to the RhinoScript.tbl file located in your Rhino 6 \ Plug-ins directory to your project.
You can then add this code to your button and have access to RhinoScript functionality.
var rhinoscript_object = RhinoApp.GetPlugInObject("RhinoScript");
if (rhinoscript_object == null) return;
var rs = (IRhinoScript)rhinoscript_object;
rs.SetDocumentUserText("Key", "Value");
@Trav I teste you code:
“if (rhinoscript_object” return always null, the script stop on “if” line an return
thanks
GetPluginObject wont return an object if the plug-in you specify isnt loaded. You need to open the Plug-in Manager and ensure RhinoScript is checked and restart Rhino.
Suite…, this will allow you to move faster.
I gone create a plugin with a installer (visual studio), there is a away to load this plugin (RhinoScript)
on frist installer?? with no user interference?
Thanks.
This plug-in is generally loaded by default unless you’ve unloaded it or you have virus scanner or something blocking it.
There’s no need to use RhinoScript for this. If you are trying to perform the C# equivalent of what one of the rhinoscriptsyntax functions does, I would recommend looking at the rhinoscriptsyntax implementation as that just directly calls RhinoCommon. For GetDocumentUserText
you can look here
For C#, you would just call
string a = doc.Strings.GetValue("var1");
Hello @stevebaer, I test you example but there is a error on DOC.
Can be a using lib missing? I already check all this:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Drawing;
using System.Data;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO;
using Rhino;
using Rhino.PlugIns;
using Rhino.UI;
using Rhino.Commands;
using Rhino.Input.Custom;
using Rhino.DocObjects;
using Rhino.Input;
using RhinoScript;
using RhinoWindows;
Thanks
‘doc’ refers to Rhino.RhinoDoc.ActiveDoc, the plugin’s ‘RunCommand’ method provides it as an argument. If your outside that method you’ll need to grab it explicitly like this “var doc = Rhino.RhinoDoc.ActiveDoc;”. Although I’m not sure if this is best practice.
Cheers,
Matt
@Trav ,
I have this code, I need check is empty or not:
var Selec = rs.GetObjects("selecionar objecto");
if (Selec.Length == 0)
MessageBox.Show("nor enpty");
If “Selec” not empty this script work, but if “Selec” is empty ther is a error.
Wy this appen?
