Thank you still though, Anders. I am thinking that because it’s a MorphControl object, maybe it is an exception. I don’t get access to the standard rs. curve stuff such as the CP / grip style functions for the control morph object.
I think Cage Edit used to work so that you could:
Set a curve as a control
explode it
Manipulate it
Set it as the cage again, and the difference between the explosion would be manipulated
And it would update. But I’m unsure.
| Replace(self: ObjectTable, objref: ObjRef, newObject: RhinoObject) -> bool
| Replaces one object with another. Conceptually, this function is the same as
| calling
| Setting new_object attributes = old_object attributes
| DeleteObject(old_object);
| AddObject(old_object);
| objref: reference to old object to be replaced. The objref.Object() will be deleted.
| newObject: new replacement object - must not be in document.
| Returns: true if successful.
